Steam Vacuum
EBEBRATT-Ed
EBEBRATT-Ed Member Posts: 20,394
If you want to see the power of steam going into a vacuum check out this U tube video
Steam Vacuum/making
  • Pumpguy
    Pumpguy Member Posts: 806
    I can remember watching Mr. Wizard (Don Herbert) on TV way back in the day take a screw top box shaped gallon can, fill it with steam from a tea kettle, then screw the top on and run cold water over the can. The induced vacuum from the condensing steam just squashed that can.
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,137
    1700 cuft steam to 1 cuft water!!
    Do I correctly remember a Mythbusters experiment where they did that to a regular railroad tank car?
  • SteamCrazy
    SteamCrazy Member Posts: 103
    Hello, My Fellow Steam Family. Thank all for all great adviçe, I just wanted to comment on how great this Site is. Just aTruck, Car Tech I like this stuff! I Got my System  up and running with new piping. Still Insulating! SMH... About 80% in now, but it's crazy how what Mr. Hololhan talks about in his book Pocket ful of Steam Problem's are spot on. As I'm Testing my system in these Cold Month's go by and I'm experiencing first hand what happens when not fully insulated. As I went on insulating the noise and uneven heat gets better.  One of the other challenges I face was with Two cold Radiators. My 2nd, 3rd to last Rads on my longest run. I believe that I may had created a vacuum lock. I decided to take off a rad vent while feeling it for the heat thru the rad then put the vent in just as steam gets there. And bam I got heat. Both Rads have been hot every day since.  Maybe I'm "bitten by the bug" or just Steam Crazy, but I find this steam stuff interesting!  Thanks again.
    ethicalpaul Member Posts: 8,922
    There is no vacuum lock in a 1 pipe system (I am ignorant of two-pipe systems). Regardless of the pressure in an otherwise well-operating 1-pipe system, the steam will condense and the condensation will flow back to the main.
    Your radiator vent might be failed closed, or some other explanation.
  • SteamCrazy
    Hello, EthicalPaul. The reason I said I may have created vacuum is because I was trying to make sense of what happened. Reading Dan's book he talks about how Partially Insulated pipes cause Steam to condense quickly and creat pockets in the system. At this time I'm using Veri vents on rads although fairly new I plan to replace them with TRV's once I'm fully Insulated.  Thanks for your feedback.
  • SteamCrazy
    ( Pockets of vacuum )
    OK. Uninsulated pipes aren't great, but any pockets of vacuum would dissipate quickly and wouldn't prevent steam getting to your radiators. I had completely bare main pipes for years after the former owners had the asbestos remediated.
  • SteamingatMohawk
    If you can balance the radiator vents to make every room "happy", you don't need to spend more $$ on TRVs.
    If you are using Heat Timer Varivalves, they may have too much capacity for your system. In the event you didn't know, those valves are adjustable upwards from about a #5. They cannot be set less than that.
    Check this out, especially the tables.
    https://heatinghelp.com/systems-help-center/balancing-steam-systems-using-a-vent-capacity-chart/
  • SteamCrazy
    Good info. Thanks guys.
