Valve hissing
DPK99
DPK99 Member Posts: 14
The valve to one radiator is hissing. It's a one pipe steam system with a new vent, and that vent is working well. But there is a hissing sound from that valve. I don't feel any air or steam escaping that area, nor does there appear to be any wetness on the floor near the valve. I'm wondering what to do about this sound. Replace the valve? Something else?
  • delta T
    delta T Member Posts: 884
    Is the valve all the way open?
  • luketheplumber
    luketheplumber Member Posts: 163
    what type of valve do you have? some of the cheaper brands of air valves tend to misbehave.
    Could you post a picture of it?
    Located in durham NC.
  • DPK99
    edited January 2021
    I'll double check that it's all the way open, but I think it is. Here is a pic. Can you identity the type?
    Jamie Hall Member Posts: 27,584
    Have you tried seeing if you can persuade it to stop by slightly tightening the packing nut on the valve stem?
    DPK99
  • DPK99
    Hey now! Jamie. That did it I think. The packing nut was too loose.
