Total Newbie pipe size question- adapting pipe sizes
glxie63
Member Posts: 1
Such a newbie I don't even know which category to put this in so...Main Wall! I've ordered new steel radiators for some renovation in my house. Contractor told me 3/4" pipe. New rads are 1/2" pipe. (Other radiators are simply old school cast iron in other parts of house.) Is this simply solved with pipe adaptors? Please say yes. (That's what rad company said but would like to hear from unbiased knowledgeable folks.) Thanks for any feedback
Yes. There are adaptors and fittings available to adapt pretty much any pipe size -- or material -- to pretty much anything else. That said, your local big box store will probably look cross-eyed at you for even the simplest things -- but they are out there, and easy to get. And usually cheap. It's a matter of knowing what you need to adapt to what, and going from there.Br. Jamie, osb
Adapting the pipe sizes is simple as Jamie pointed out, but adapting new low mass steel panel rads to a system with old high mass cast iron rads is not so simple. Even if you size them correctly, the new rads will not perform like the old ones. Also, the old piping system needs to be considered carefully. Is it an old gravity direct return? A monoflo?
At the very least, the new rads should be put on a separate zone with their own circulator and thermostat.
If you post some pics of your boiler, piping and old rads, that would be helpful in giving advice on how to proceed.Bob Boan
1/2" NPT, or 1/2" BSPP (British Standard Pipe Parallel thread), or 1/2" BSPT (British Standard Pipe Taper thread?
Tell us more about the new radiators.
https://en.wikipedia.org/wiki/British_Standard_Pipe
Yes, many imported radiators would have a BSP straight thread, be sure to check.
With some tweaking you can put a male BSP thread into a female NPT, Loctite or hemp
But not a male NPT into a female BSP, only 1 or 2 threads will engage. Bob "hot rod" Rohr
Living the hydronic dream0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
