Water hammering steam pipe... long term damage question?
LS123
Member Posts: 476
Happy holidays...
I have single pipe steam heat... I have closed one heater from getting steam... occasionally... the steam pipe going to this radiator start hammering so loudly, and also noticed during water hammering, there are small amount of water leaking..
1) Is there long term damages to the steam pipe with this occasional water hammering?
2) How is it that water getting in to the steam pipe for this radiator?
3) Is it possible water from return line is being pushed in to the steam pipe? if so what might be the possible reasons for water to get in the steam pipe?
Thank you!
LS123
Thank you!
LS123
@EBEBRATT-Ed @Jamie Hall
Thank you both... very useful info..I will try both of your suggestions.
Happy holidays!
\-LS1230 -
Happy holidays!
Thank you @motoguy128!...I used suggestions from @Jamie Hall and @EBEBRATT-Ed... Water Hammering has stopped.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
