Evaporator Connection Not What Expected
BigRob
BigRob Member Posts: 332
Hi all, I picked up an evaporator for a wine room application and the TXV connection is not what I expected and I’m confused. Is this a SAE connector and why is it sealed? There are also cotter-like pins around the perimeter. Do I cut this off?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    Seems like you have half the system
    EBEBRATT-Ed Member Posts: 20,137
    I never saw one of those. Maybe some type of Chatliff connector
  • BigRob
    It's weird - almost like the TXV pierces that metal covering the pipe back to the exchanger. I guess I'll just cut it off and sand off the coating.
    mattmia2 Member Posts: 16,641
    Looks like some sort of quick connect precharged system.
    Before you cut it off, make sure the tubing is a metal and size you can connect to.
    pecmsg Member Posts: 7,037
    Standard Flair connection. The holes are to alloy moisture to drain rather then break the flair nut.
    I prefer remove them and use Stay Brite #8 to solder in the x-valve.
  • ratio
    ratio Member Posts: 4,229
    Ah, maybe it's a metal dust cap inside a flare nut?
  • Solid_Fuel_Man
    Sure looks like a metal: what we call a frost plug inside a typical flare nut. Can you pry it out?
  • BigRob
    Thanks for all your suggestions. I’ll give it a gentle pry and report back.
