Air vents
Hi all
so I have a 2 storey 1940 Craftsman home. Peerless boiler single pipe steam system.
I’ve replaced several air vents on the radiators and some of them continue to vent / hiss even when the radiators are hot. I’ve checked and corrected pitch when needed but it’s pissing me off they vent enough that I have to top up the water every week.
Normal or am I missing something?
    EdTheHeaterMan Member Posts: 12,508
    How much water does it take to "Top Off" the boiler? Are we talking gallons or just a few quarts? (less the 30 seconds of opening the feed valve)
    I think that a quart or 2 a week would be acceptable. the hissing of the vents is more of a problem. A properly sized vent system is relatively quiet. what is the pressure setting on your controls? Is there a working Main Vent at the end of each main steam pipe?
    Limey68
  • Limey68
    Limey68 Member Posts: 17
    Hi Ed
    Between couple quarts and a gallon
    Pressure switch on boiler is set at 2 psi
    I’ve traced each vent starting closest to the boiler and they seem to be operating correctly. What’s puzzling is a few new air vents on the radiators seem to be staying open. Just today I changed one out for another new one and that radiator is quiet now.
    is there a high failure rate on these vents from new?
    ethicalpaul Member Posts: 8,933
    Where did you get the vents and what brand/model are they?
    EBEBRATT-Ed Member Posts: 20,491
    @Limey68
    Does your system have any main vents?
  • Limey68
    Paul
    Home Depot, Plumbers Edge brand with either .04 or .05 hole depending on rad location
  • Limey68
    @Limey68 Does your system have any main vents?
    Ed I see vents close to the boiler and at the end of some main lines. Look original and initially vent then shut off so I assume they’re working correctly.
    Jamie Hall Member Posts: 27,584
    Paul
    Oh dear. Well, go to StateSupply or someplace like that and, for main vents, get yourself some Gorton #1s and for the radiator vents get some Vent rite #1s.
    I'm sorry to say this, but the Home Depot vents have not proven to be very satisfactory.
    Yeah I’m not really a HD hater but for vents they are absolutely horrible. My go-to is Maid o Mist from supplyhouse.com
    Under $10 each
  • Limey68
    Thanks guys, I’ve taken note of suggested brands. I’ve now changed out 2 rad vents and the system is running much quieter.
    Must be a crap shoot with the Plumbers Edge brand but I’m learning as I go.
    Merry Christmas to all 🍻
