Mounting Charleston Rads Vertically
Jakek
Jakek Member Posts: 57
On the streamradiators.com gallery they have a photo of what appears to be a one-pipe Charleston radiator mounted vertically. (2nd row down.) Will this actually work with these?
    Jamie Hall Member Posts: 27,517
    Sure. So long as it slightly pitched down to the right, each element can drain as it needs to, and that's the critical thing.
    ethicalpaul Member Posts: 8,925
    Quite a bit smaller EDR looks like, hope the kitchen is warm :)
  • I would be concerned that they appear to have much less thermal mass than the originals they have replaced.
    In a hot water system, they would be fine, but for steam, maybe not.--NBC
  • Jakek
    edited December 2020
    I have one. As expected it cools off quicker than a cast iron rad with the same BTU rating. But in removing the old in-wall radiator I was able to considerably improve the room's insulation so it's a wash heat wise. I like the look of the Charleston and the fact it leave the floor open.
    To @ethicalpaul point, yeah, in the gallery photo the Charleston they show is probably 1/10 the output of the original. Definitely a deceptive picture if people are to assume the two are equal.
