site glass
The critical question is -- where does the water level come to if you leave the system off for half an hour? If you add water, and it eventually comes back higher, there is a risk of overfilling the boiler, which you do not want. In that case, try setting the time delay on the feed to a longer interval, so the feeder waits to see if it really does need water before feeding.
I would not set the feeder to add more. Rather, I would have the time delay -- and let it feed a gallon, rather than the option which some feeders have to fill until the LWCO clicks off.
You ask at what level in the sight glass will the boiler run for a few days. Well now. Can't answer that one, as it depends on how much of a leak you have and how much water is in the boiler itself for various elevations.Br. Jamie, osb
left alone appears at 1/3. last night brought to 1/2, this morning now sits 1/3. is having it sit at 1/3 and the system starting then stopping to refill a bad thing? How do i delay the feeded?0
It's not really a bad thing to have it start and stop. As to how to delay the feed, that depends on the make and model of the water feeder. On many, it's dip switch settings inside. It will be in your owner's manual.Mark929 said:left alone appears at 1/3. last night brought to 1/2, this morning now sits 1/3. is having it sit at 1/3 and the system starting then stopping to refill a bad thing? How do i delay the feeded?
And if you are adding that much water, you need to find that leak. Leaks never get smaller with time -- and as I'm sure you are aware, constantly adding fresh water is really hard on the boiler.Br. Jamie, osb
found the delay switch will add a minute or two. as i mentioned small leak in daughters bedroom - dump 1 gallon a week, i know that plays a part in the feeder # going up...but cant find any other place. wet returns ive read can slow down h2o return which may play a part- 110 yr old home. any other advice? you helped me 7 yrs ago after a terrible install with poor piping structure which when i showed them your comments they reconfigured!! THX, JAMIEHALL big time.0
so change from LWCO to 1 gallon and extend timer a minute or two?Jamie Hall said:The critical question is -- where does the water level come to if you leave the system off for half an hour? If you add water, and it eventually comes back higher, there is a risk of overfilling the boiler, which you do not want. In that case, try setting the time delay on the feed to a longer interval, so the feeder waits to see if it really does need water before feeding.
You ask at what level in the sight glass will the boiler run for a few days. Well now. Can't answer that one, as it depends on how much of a leak you have and how much water is in the boiler itself for various elevations.0 -
Exactly. Or even a longer delay, if it's available -- but certainly from LWCO to measured 1 gallon.Mark929 said:
i do notEBEBRATT-Ed said:@Mark929
Do you have any wet returns under the basement floor?0 -
Delay is factory set at 2 minutes will go to 4. And change LWCO setting to fill + 1 gallon - see how that fairs.Jamie Hall said:
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
