Infrared pics of radiator, again
hot_rod
Member Posts: 27,129
Though I would see how a radiator heated with just about 1/4 of it filled with water, starting with 63° fill water.
Within 20 minutes you could feel heat convecting up thru the sections. After about an hour, conduction had the very top at about 90° and the entire radiator was warm and convecting from the lower section at about 116°. So the top at 90°, bottom at 116° average temperature 103° to calculate heat output?
Makes me wonder how it would look if the top sections were not connected, like a steam radiator.
I suspect after a period of time conduction warms the entire iron vessel.
I'll look again in an hour or two.
Hot Rod's workshop. 1/2 pex runs to poor unsuspecting radiator. Camera ready.
Love it!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Boys and Toys.....show off....I am jealous!
What would be interesting is a video of a steam only (no top connections) radiator attempting to heat as a hot water rad.
Maybe with an air vent where the steam air vent is located...with and without.
We have all seen a steam only rad with air vents drilled into each section.....it was in the salvage yard BTW.
To all...have a good Thankfull day!0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 15.9K Strictly Steam
