Water capacity for Dunkirk PSB-7D 225,000 Btu steam boiler
Greg_44
Member Posts: 5
I am trying to determine the water line capacity of the Dunkirk PSB-7D 225,000 Btu boiler. I have already called Dunkirk and got the wrong information. Any suggestions?
I could do that. I was hoping there was a chart or something like that.0
It is likely that the volume of water per inch of drawdown is variable, since it will depend on the interior geometry of the boiler. Not knowing why you need to know, I would suggest that you make your own chart. Start at the top of the sight glass, draw off a gallon, record the measurement, rinse and repeat to the bottom of the sight glass. Note that this will include the volume out in any drips, if there is a wet return, so long as the water level is above the Hartford loop.Br. Jamie, osb
The spec sheet I found says 7.4 gallons. Search Dunkirk's website0
Where did you find this info? I could only find the low water cutoff water gallons capacity of 5.7 gals.0
- 128 Chimneys & Flues
