I Have No Idea...
Skim port?
New England SteamWorks
newenglandsteamworks.com
  • ratio
    ratio Member Posts: 4,243
    Relief for all the extra water that the steam carries out, so it doesn't have to fight it's way back in through the riser?
  • But it's capped. Doesn't go anywhere....
  • ratio
    I don't even… What‽
  • Or does it go somewhere? After enhancement, I am not sure. I only have the one picture the customer forwarded, in regard to another matter.
  • Namely, this:
    EBEBRATT-Ed Member Posts: 20,224
    Boiler bypass for steam :):):):) Must have been a hot water guy.
    SuperTechluketheplumber
  • JUGHNE
    JUGHNE Member Posts: 11,552
    Maybe started to add the water fill connection there and thought otherwise. I have seen a steamer with water fill at that point.
  • Perhaps they removed one of these and thought the three-quarter inch line was necessary, which in this case it wouldn't be because you have the Hartford Loop
  • SlamDunk
    SlamDunk Member Posts: 1,807
    edited November 2020
    The end cap is puzzling. Otherwise, I would say they intended to overfill boiler to that point to prevent waterline rot during summer.
