Combustion analysis not needed during a PM?
I'm a homeowner and Just had maintenance done on my single pipe steam boiler (Weil-McLain Gold with EZ-Burner) and the plumber said it didn't need a combustion analysis because it's not a high efficiency boiler. The boiler is full of tags from previous maintenance checks all with combustion analysis results. Am I mistaken in requesting this be included in an annual PM?
    EdTheHeaterMan Member Posts: 12,510
    edited October 2020
    Wrong Answer. You lose. Need another contractor
    Annual PM on oil heat is designed to get the peak performance for the upcoming season. If he changed the nozzle, adjusted the electrodes, and brushed the lint off the fan and housing that builds up over the season... then the air/fuel mixture must be checked to see if adjustments are needed to get the best performance.
    Call the boss and ask what the company policy is.
    If he did not do those things with the PM and the company agrees then I would not let him back into the house, give him a bad review on Google, Yelp, and anywhere else that will listen.
    MaxMercyethicalpaul
    ethicalpaul Member Posts: 8,933
    I had a crusty old oil fired hot water boiler in CT and my service company left me an analysis printout every year.
    HVACNUT Member Posts: 7,527
    edited October 2020
    You have an oil, cast iron wet base boiler. It absolutely needs smoke, draft and combustion tests. You need a competent tech, not just a plumber. He probably doesn't even own a digital analyzer.
    MaxMercy
  • Soilidventur
    Soilidventur Member Posts: 7
    Thanks for the comments. Just to clarify the EZ burner is gas fueled.
    I'm confused about the comments re: plumber vs tech. Every listing for boiler repair/maintenance/replacement is a plumbing company. Are there secret boiler technicians somewhere that I don't know about in the Boston,MA area?
  • STEVEusaPA
    Gas burner needs a combustion test too, draft and gas pressure checked.
    MaxMercy
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Gas or oil both need a combustion analysis especially when we are talking about a Gas conversion burner. You need to contact Denny Reardon and old gas man from way back.
  • Tim McElwain
    Denny Reardon can be reached at dennys.service@yahoo.com
