What does this pressure relief do?
dkirkwood
Member Posts: 25
This valve (in pic) is in the water supply line that goes to my auto feed control valve for my boiler. The boiler is Burnham Steam--it and the controls and autofeed are about 2 years old.
What does this valve do? What are the 3 vertical projections for? I assume it has something to do with pressure relief of reduction, but I don't know if that is right.
Also, it is dripping in the center, into the pipe that extends down--the pipe simply lets the dripped water onto the basement floor--is the dripping a sign the valve is bad--or is something else wrong?
Any help is appreciated. Thanks!
and if it's dripping, it needs servicing at the very least -- the drip indicates that it isn't functioning properly.Br. Jamie, osb
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
