Boiler pilot light
dave789
Member Posts: 3
Hi ,
My girlfriend recently bought a house with a boiler heating system. During the home inspection, it was turned on and run successfully. We had the gas valves replaced by the previous owner (as they were all pretty old valves and the inspector recommended it). So, I believe the pilot light just needs to be relit.
It looks like there is an ignitor button (lower right in the pic of the open panel), but it doesn't seem to be connected to anything. I feel like the pilot is in the opened burner panel in the lower middle of the pic.
Any thoughts/ideas if that is correct? It is a Valliant GA100-8 SPVD.
Thanks for any help.
Dave
Dave
The pilot is at the end of that ~1/4" aluminum tube that goes underneath the burner. turn the valve to "pilot" you need to get a match or grill lighter to the burner at the end of the tube and hold down the red button on the valve to turn on the pilot burner and hold it until the thermocouple heats enough to hold the valve open.
Close the little door once it is lit and turn the valve to "on". whoever installed it kinda did a hack job.
Get that flammable stuff off the top of the boiler.2 -
Thanks for the reply!0
That's what I was thinking too about the igniter not being hooked up to anything.0
I've never heard of replacing a working gas valve just due to age, but I suppose it couldn't hurt anything.
I'd be more concerned with the signs of flame rollout (the burned-looking spot going up & left from the rectangular opening). I can't tell if it's old or an ongoing problem, but you should get it checked out by someone who knows what they're doing.
2 -
- 120 Geothermal
- 169 Indoor-Air Quality
