Type of piping for pool heater
karenn
karenn Member Posts: 5
I am about to get a 3/4" gas pipe installed for a pool heater. I am trying to figure out what type of piping I should get installed. Does the CSST piping make noise when the gas is on for the pool heater? (it will be installed in my attic space). Should I go with CSST and galvanized/black or should I go with Galvanized only?
  • ChrisJ
    ChrisJ Member Posts: 17,519
    I do not believe CSST makes noise but pretty much everyone on this forum will tell you to use black iron pipe.
    mattmia2Solid_Fuel_Man
  • JUGHNE
    JUGHNE Member Posts: 11,604
    I would second the black threaded pipe.
    Your installer has determined you need only 3/4" supply?
    Heater in the attic.......never heard of that one.....but then I am just a country boy.
  • karenn
    The heater is not in the attic, but the piping will be installed in the attic.
  • karenn
    I guess i will go with Black iron. Not sure if I am convinced yet.
  • Solid_Fuel_Man
    CCST is glorified appliance connector. We cannot legally run an appliance connector in a concealed space due to its paper thin wall construction. Yet.....CCST can be run pretty much everywhere.  I would only run black pipe in my own home, or copper/black if we are talking propane.
    mattmia2Zman
    mattmia2 Member Posts: 17,476
    CSST has a tendency to get holes burned in it and start a fire with nearby lightning strikes.
    Solid_Fuel_Man
  • Zman
    Zman Member Posts: 7,614
    There are less safe ways to move natural gas than CSST. Black pipe is preferred. https://www.dailymail.co.uk/news/article-2108346/Chinese-villagers-carry-giant-balloons-stolen-natural-gas-heat-homes.html
    Albert Einstein
    EBEBRATT-Ed Member Posts: 20,482
    I agree that CSST is junk. I have used it only a couple of times. Temporary feed to a couple of roof top units, above a drop ceiling with 2' square tiles almost touching the joists. Couldn't get a 10 footer in there no way and the CSST was protected.
    Check the size of your pool heater they are usually 250,000-300,000 btu. More like 1" or 1 1/4" pipe
  • karenn
    Thank you all. I am convinced. I will go with black pipe
  • @JUGHNE said,
    "Your installer has determined you need only 3/4" supply?"
    Your pool heater must be VERY small. You can't get much gas out of a 3/4" pipe. What is the input rating of the heater?
  • JUGHNE
    Maybe with a short run with 2 PSI system?
    Or propane
    JUGHNE
