Damn plastic to plastic threaded fittings .... damn the jam
Please, can anyone offer a solution to the jamming of my threaded plastic whole-house water filter bowl jamming into the threaded plastic housing? It's nuts. Even with the most expensive dielectric food-grade lubricant, and only hand tightening the unit, the plastic bowl jams so tight I literally rip it off the mount every time I have to change a filter. If there is no lubricant that can prevent this, how about a recommendation for a 3/4" feed prefilter that uses ... say .... plastic to metal, for example.
This is the same problem as PVC threaded pipe jams.
  • JUGHNE
    JUGHNE Posts: 11,645
    For the filter bowl, you shut off the supply in and discharge out....but do you have a way to release the pressure within the bowl. Some have a button to release the pressure.
    STEVEusaPASuperTechdelta T
    mattmia2 Posts: 18,261
    Mine seem to bind on the o-ring a lot more than the plastic.
  • HomerJSmith
    HomerJSmith Posts: 2,834
    Ya! it's a common problem. Silicone grease doesn't seem to help.
    I haven't done this but I think I'll try it. Clean the threads, male and female with lacquer thinner. Then I would lubricate the threads with graphite power. You can get graphite in a auto parts store. Graphite is inert to plastic and a great lubricant.
    pecmsg Posts: 7,619
    One piece of grit, one grain of sand cuts the plastic and form's notches that grab when trying to remove. Wash both Male and Female threads well before tightening. The O-Ring is the seal, a little food grade grease on there, hand tighten, slowly turn on if leaking replace the O-Ring.
  • Ya! it's a common problem. Silicone grease doesn't seem to help.
    Lacquer thinner on potable water?
  • Big Ed_4
    Big Ed_4 Posts: 3,585
    Plumbers grease on the threads and drop the pressure when opening .....
  • JUGHNE
    If you have no pressure release button/valve, you can shut off the supply valve. Leave the outlet valve open and drain some water (drop pressure on cartridge) from a sink.
    At least 4 people here think this will not unscrew easily under pressure......this is true of other situations also.
    hot_rod Posts: 28,558
    There used to be some 1/4 turn twist lock style that worked much better. I think they were brass body, stainless canister. Probably gone due to low lead requirements?
  • HomerJSmith
    edited August 2020
    realliveplumber, The threads donna contacta potable water, besides the evaporative quality is rapid and it may be a silicone grease cutter. You're not taking a bath in it. Just saying.
    It's a pain in the you know what to use a 24" pipe wrench to crack the threads on a whole house filter's plastic housing. No pun intended.
  • I have also found if you use two filter wrenches with the handles 180 apart on the filter, that the filter will come off with a LOT less pull. I also use stem lube on all my o-rings and threads.
    Rick
