London Apartment Outdoor Waste-Line?
D107
D107 Member Posts: 1,945
edited July 2020 in Plumbing
Surprised to see this given London's winter cold climate.
  • ratio
    ratio Member Posts: 4,258
    They do all kinds of crazy stuff over there. You should see their electric system!
  • JUGHNE
    JUGHNE Member Posts: 11,591
    That is very typical there. It is just DWV and should not hold any water. The alternative would be cutting up a lot of masonry structure.
    In Jackson MS, I saw a lot of H & C on the outside of the building.
    Might freeze every 5 years and get replaced in the same manner.
    A brother that lives near there cut his water line by just digging down 15". They can put water heaters in the unheated attics.
    D107
    mattmia2 Member Posts: 17,204
    I believe London also runs many of their mains at very low pressure and you need a water tank and pump in your house as well.
    D107
    Jamie Hall Member Posts: 27,513
    It's not just London. Any city or town -- even most of the great palaces. As @ratio noted, you simply don't run water or waste -- or electric or 'phone or cable or anything else through those structure unless you absolutely have to.
    My daughter's flat, when she lived in Edinburgh for a while, was relatively recent -- I seem to recall 1830 or so -- and everything ran up outside (her first flat was older -- 1540).
    And yes, water mains pressure is usually relatively low by our standards, and one has a cistern at some high elevation in the flat or house filled at low pressure through a float valve (just like a US water closet). It's not, however, just for relatively low pressure -- it completely flattens the variations in water pressure, as the demand over a day is quite constant. It does, however, mean that all your valves and fixtures are designed to operate on low pressure -- perhaps 15 psi -- and really don't work well on our higher pressures in North America.
    Never mind the electrics -- 220 volts 50 hertz over there vs. 120 volts 60 hertz here.
    D107
    Steamhead Member Posts: 18,625
    We see this in Baltimore, mostly on rowhouses that are older than indoor plumbing.
    Consulting
    D107
  • JUGHNE
    I have wondered about the WC in these situations.
    It seems a wall hung would be in order.
    Or elevated WC with piping on floor covered maybe by box.
    D107
  • D107
    Found another online; perhaps easier to maintain? Probably less prevalent in the residences of the wealthy due to aesthetics?
  • TAG
    TAG Member Posts: 805
    I own two places in Philadelphia with old style CI outside. One is a trinity the other a typical row -- they both have the second floor bathrooms that exit through the wall to the outside --- 3" pipe down --- turns back into basement and same up to roof for vent.
    Sealed with lead
    I might note that both of the photos are brick... thick brick, but brick. Try it in two foot plus thick solid stone! Some very ingenious plumbing...
    Canucker
  • JUGHNE
    How else would a cat burglar get to the 2nd and 3rd floor windows?
    They make for good movie scenes also.
    Could double as fire escapes.
  • D107
    @JUGHNE "Could double as fire escapes." Just last week in the news they showed somewhere in the US two teens fleeing a fire through the apartment window using an outside pipe.
    JUGHNE
