Shielded, twisted pair wire for Lochinvar cascade feature.
JohnNY
JohnNY Member Posts: 3,393
Hello, all. Does anyone have a source for buying a small quantity of shielded, twisted pair wire that I can use to link two boilers?
Many thanks,
John Cataneo
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
  • ratio
    ratio Member Posts: 4,264
    Around here, one can get a cut of wire at an electrical supply house without too much difficulty, most|all of them carry at least something shielded. Online comes to mind, if you've got time to wait.
    A 500' roll of 18/3 stranded shielded plenum-rated wire is only around $100. I know I'd hate to buy that much when I only need a few feet, but if it's a get'r'dun today kind of thing, that might be the fastest, if the electrical supply houses don't want to make a cut for you.
    JohnNY
    mattmia2 Member Posts: 17,474
    just buy a cat 6a cable. is the actual impedance important?
    ChrisJ
    Also, this place will cut a lot of different cables:
    https://www.wireandcableyourway.com/
    JohnNY
    Looking at the manual, it looks like virtually any shielded 1 pair control cable would work.
    hot_rod Member Posts: 27,846
    I bought this for some solar sensor wiring.
    JohnNY
  • Gary Jansen_4
    Gary Jansen_4 Member Posts: 77
    I would think that most hardware stores and electronic shops would sell it by the foot.
    That's how it is in Wisconsin.
    That being said, I can't count the number of boilers, including Lochinvar, that I have used standard 18-2 thermostat wire for communication, and it has worked just fine.
    Thanks Gary
    HVACNUT Member Posts: 7,526
    Does Lochinvar recommend shielded cable or is there the chance of interference to other equipment?
  • Zman
    Zman Member Posts: 7,614
    Lochinvar recommends it. Controls companies use miles of shielded wire. I usually grab some drops from a buddy that does controls work.
    Albert Einstein
  • JohnNY
    No, it's not. Thank you.
    Classes
  • Gary Jansen_4
    How much do you need?
    I have tons of the stuff?
    The shield usually isn't important until you get in an environment where it is then you end up with weird intermittent issues.
    It also might not be to protect its signaling from interference but to keep its emissions within part 15 limits.
    ratio
    Part 15, part 16. Whatever it takes.
    JohnNY
  • JohnNY
    I need about 7 feet of the stuff but maybe I should just buy a roll.
    Classes
  • Gary Jansen_4
    I'll send some out today.
    Thanks Gary
  • Gary Jansen_4
    If you are cascading 2 lochinvar boilers, then I am assuming you are running a header sensor. And possibly an outdoor sensor.
    Do you need the shielded wire for those 2 sensors also?
    Thanks Gary
  • JohnNY
    Thanks Gary
    Gary, thank you so much. That's fantastic and very generous of you. The two sensors don't require shielded cable. Again, I'm very grateful.
    Classes
  • Wellness
    Wellness Member Posts: 154
    edited June 2020
    Not sure what Lochinvar's requirements are, but shielded twisted pair cable is often incorrectly provisioned in computer network environments without grounding, thereby defeating the whole purpose of having the shield. It's not simply a matter of terminating the wire leads.
    The shield does block some types of noise without a low impedance at RF connection to ground, but for other types of noise the shield has to be properly prepared and connected to a shielded modular connector or jack.
  • JohnNY
    Received, @Gary Jansen_4 !! Thanks a million! I hope I can do something for you some day.
    Classes
