The Case for Copper
woobagooba
in Plumbing
https://www.vice.com/en_us/article/xgqkyw/copper-destroys-viruses-and-bacteria-why-isnt-it-everywhere?utm_source=pocket-newtab
I'm in the middle of making a PEX versus copper decision for an ongoing reno. Probably will do a mix.
Does it still work if the copper is green? How do you stop poles, hand rails etc from turning green?woobagooba said:https://www.vice.com/en_us/article/xgqkyw/copper-destroys-viruses-and-bacteria-why-isnt-it-everywhere?utm_source=pocket-newtab
Does it still work after build up lines copper water pipes?
The reports I saw on COVID-19 said it lasts for up to 4 hours on copper.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Copper hasn't done much for the spread of Legionnaires Disease.0
I'm thinking it's more of a "Yeah, it does help some, but you still need to disinfect things so it's no magical cure" type things.pecmsg said:Copper hasn't done much for the spread of Legionnaires Disease.
The inside of the pipe tends to build films of minerals and organic matter that insulate the water from contact with the metal.0
CuVerro claims anti-microbial properties for tubing made of its copper alloy. From a quick perusal of its manufacturing partners it doesn't look like any tubing manufacturer is using it yet. https://cuverro.com/products/copper-tube-rod0
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
