Lockout alarm A01 ignit error - Utica boiler
Hi, I got the A01 ignit error code on my Utica boiler today. I lost power Friday for 3 hours not sure if it has anything to do with that and not sure if it’s been like this since Friday. I seem to have heat still though? I hit reset today and it popped back to normal and then an hour later went back to the code, but I turned my heat up (ecobee 3) and it just went back to operating normal without having to press the reset button.
My plumber said it’s probably the sensor that needs to be cleaned and he said he’d walk me through it on the phone as it’s a 3 min fix.
Any thoughts or ideas?
    EBEBRATT-Ed Posts: 21,328
    Sounds like you plumber knows what to do
    Is that what you think is the issue? He wants to walk me through it on the phone. I just don’t want to mess something up.
  • Ironman
    Ironman Posts: 7,975
    edited February 2020
    If he's trying to get you to clean the flame rod, you need to be careful not to tear the gasket when removing it. It's best to have a small tube of RTV caulk on hand before attempting it.
    Also: use a dollar bill to clean it, not sand paper or anything abrasive.
    Bob Boan
    He said something about the heat sensor? He said cleaning that will fix the issue. I woke up this morning with no heat so I hit reset again and it got the heat going again and still seems to be working.
  • Ironman
    From your description, it sounds like the flame sensing rod. Cleaning them is normal maintenance and the first step after confirming proper gas supply pressure. In this case, that has to be assumed for the moment since you likely don't have a manometer or the training of its use.
    Bob Boan
    NickB2005
    Thanks! Probably better I just call someone in to make sure it’s done right. My plumber is away for the winter so that’s why he offered to walk me through it on the phone.
  • Ironman
    It's very simple to do: only two screws hold it in.
    Bob Boan
  • Oh, that isn’t bad. So, how would I clean it after taking out the 2 screws? Also, I assume I’d have to shut off the whole heating system prior to opening it?
  • Ironman
    Just turn the power off at the boiler switch. The rod pulls straight out in the direction that it’s pointing. Wipe it good with a dollar bill and re-install it.
    The RTV is in case the gasket splits.
    Bob Boan
    NickB2005
  • Hi @Ironman - thanks for your help in this thread. I'm having a similar issue on my Helix Dunkirk boiler (with the A01 ignit error), which looks to have the same interior as in the graphic you posted in this thread in Feb 2020.
    Can you please confirm how to turn the power off at the boiler switch? I'm not seeing a way to turn mine off, before I attempt to take out and clean the flame sensor.
    Thanks,
    Steve
