Boiler Efficiency W/Programmable Thermostat
Also, are there any recommendations for a WiFi thermostat for boilers that may also be able to control a ductless mini split A/C unit.
Thanks for the help
That's one of those discussions. Which goes on and on... and the answer is, it depends. There is sort of a general consensus that you may save a tiny amount of fuel for steam and hot water systems with turndowns during the night of a few degrees. Turning up in the morning, down again during the day, then back up in the evening... unlikely to save significantly, if at all. Turning down at night more than a few degrees. Also unlikely to save.
Radiant floors etc. you won't save anything at all -- it may cost you. Forced air you can use larger turndowns and turndowns during the day, but some would say comfort suffers unless the turned up temperature is higher, at which point...Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England2 -
Understood, anyone have smart thermostat reccomendations to work with both of my systems?Jamie Hall said:That's one of those discussions. Which goes on and on... and the answer is, it depends. There is sort of a general consensus that you may save a tiny amount of fuel for steam and hot water systems with turndowns during the night of a few degrees. Turning up in the morning, down again during the day, then back up in the evening... unlikely to save significantly, if at all. Turning down at night more than a few degrees. Also unlikely to save.
Radiant floors etc. you won't save anything at all -- it may cost you. Forced air you can use larger turndowns and turndowns during the day, but some would say comfort suffers unless the turned up temperature is higher, at which point...0 -
Is the ductless system controller hardwired or are you using a remote?0
When I bought the house i received a remote control. It is a Mitsubishi.HVACNUT said:Is the ductless system controller hardwired or are you using a remote?
Depends how much energy your envelope can lose in a program period.
It also depends on how well the boiler, and it’s emitters are sized for the load coming out of a set back program.
It also depends on how much comfort you are willing to sacrifice. Mass always lags setpoint. Which leads to lack of comfort.1 -
Yes it is subjective, I was just curious what was generally seen.Gordy said:Depends how much energy your envelope can lose in a program period.
It also depends on how much comfort you are willing to sacrifice. Mass always lags setpoint. Which leads to lack of comfort.0 -
Set backs are more for comfort then savings. The savings come over long periods, 24, 48, 72 hours. 4 or 8 hours you probably cant measure the difference.0
Ok, thanks for the info guys. Any reccomendations on thermostats?? ^0
I think you are stuck with either the remote or possibly a wired thermostat that will work with the Mitsubishi only.0
If you are getting a new boiler get a high eff. wall hung and forget the night setback and use outdoor reset.0
How many BTU can you get a high efficiency wall hung in? I'm not versed on boilers all that much yet..unclejohn said:If you are getting a new boiler get a high eff. wall hung and forget the night setback and use outdoor reset.
I think it’s debatable. Some can probably save on daily setbacks while away. However if you are saving dollars by daily setback schedules, I would say the envelope is pretty bad.
1 -
Consumer comment. Never mind the energy savings, I like a cool bedroom at night . Like 60 degrees. Big down comforter . Hence my use of setback thermostats. I only heat to 67 degrees during the day. In southern New England, 1600 sqft house I burn 550 gallons of oil per year including DHW. Heating is copper finned tube baseboard installed before the House was insulated so it warms up pretty quick0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
