Oil furnace fan not running
JHolden
Member Posts: 4
I have a issue with my oil furnace I am trying to diagnose. The issue is on the fan/motor on the exhaust vent. When the furnace tries to kick on the motor buzzes and tries to run but seems to be stuck. If I open the circular port of the vent pipe I can turn the shaft by hand and help it, to start and runs OK, and the furnace lights and all is great until it shuts off. When the power is off the shaft/fan spin freely. Is the motor dead? or is it the capacitor? or something elsoe I havent figured out.
I need to get this fixed soon as we are in Maine, its cold and I have a 8 month old. We have a wood stove, and backup heat but I would like to get the primary heat back online.
The whole unit is similar to the amazon link below, however a slightly different arrangement its expensive so I would rather just replace one specific part of this assembly if possible
https://www.amazon.com/dp/B000CDAOFG/ref=cm_sw_r_wa_api_i_JyGeEb33ZJVRH
Thank you for any help!
A competent tech will quickly and easily find, diagnose and fix the problem. It's not something you want to do yourself.
For example, it could be the capacitor. You waste your time, go to a supply house, and probably get charged homeowner price for the part.
If that doesn't work, then what? The next 2 options you really can't do yourself, being motor/blower wheel replacement and/or fan/limit control, or control board.There was an error rendering this rich post.
Do you know how to test a capacitor, is that meter capable of doing it?JHolden said:I have a $200 repair budget, my fear is that a tech will eat the entire budget just diagnosing and leave me no better off.
@Jamie Hall Thanks, I have a meter so I will test the capacitor. I guess worst case its a motor replacement, I have found the part on eBay
Homeowners getting parts on flea bay scares me. Do you know why it went bad assuming it is?
Do you have the test equipment to check the pressure it produces?
Please your in over your head, get a qualified tech out.
Ask family, friends, church groups who they recommend.0 -
I can take the capacitor into work and get it tested by one of our guys, is one option.
I do not know why it went bad. the furnace was running fine, then on two occasions it wouldn't start. On these occasions if I turned the shaft by hand it was able to get going. on the last time that didn't help at all. The furnace is 20 years old, 5 years ago we replaced the blower motor in the furnace and the nozzle.
I am over my head, I get that, but I need to learn how to do these things. I have a recommendation for a local guy so I will give him a call and see what he thinks.
If we have to put off the repair to the summer we will.0 -
Thanks, I have ordered a capacitor, and a set of brushes for the motor0
- 120 Geothermal
- 394 Solar
