Ruptured Heating Lines
mepeter
mepeter Member Posts: 1
edited December 2019 in Pipe Deterioration
60-year-old house. Several Ruptured Heating Lines - They appeared to have been repaired, but water slowly leaking
A friend of my friend said something to this effect -- Finishes are saturated -- and can no longer withstand the weight. I can't remember the details. I would like to know what he meant by this
"Finishes are saturated and can no longer withstand the weight? Weight of the ceiling? floors? or?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,128
    Hello, I can only guess, but am guessing he meant that when finishes like plaster or drywall get soaked, they lose their structural capabilities and basically turn to mush. They can no longer even hold up their own weight. Clearly it's time to find and fix those leaks!
    Yours, Larry
  • dopey27177
    dopey27177 Member Posts: 916
    If you have slow leaking water something was not repaired correctly. open the ceilings and find the leaks.
    Jake
    Jamie Hall Member Posts: 27,446
    If it is either sheetrock, plaster board, or true plaster which has gotten soaked... good luck. Sometimes plaster if it was dried quickly (that is, someone found the leak and fixed it fast) will survive. Otherwise, it will fail unpredictably. If it is either sheetrock or modern plaster board, it must be replaced. There's no fix to it.
