One pipe residential steam radiator retirement at main.
I’m retiring three radiators at the main should I plug or vent them off Tees?
  • Hotdeez78
    Hotdeez78 Member Posts: 2
    I have a One pipe residential steam system. I have retired three radiators at main. What would be best to simply plug them at Tees or put 45 degree fittings and Hoffman 75 main vents for more venting?
    They are $120 each. Any thoughts would be nice thanks
    Jamie Hall Member Posts: 27,053
    Well, you have these two threads in "geothermal" -- which has nothing to do with steam heat. But that's OK. In regard to your question: the retired radiators should be plugged. However, you are looking at retiring a total of 4 radiators, and you may find that as a result your boiler is seriously oversized and may give you some cycling and efficiency problems. This should be considered; unless there is a very good reason to eliminate the radiators, I would think twice.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    We've merged these posts into one and moved it to the Strictly Steam category.
    President
    HeatingHelp.com
