VR8304m Gas valve inop
happysenior
Member Posts: 3
in Gas Heating
How can I test it ? I have power and grd. And no pilot light lit
Check to see if you are getting 24 volts at the following terminals:
PV
MV/PV
If yes, you need a new gas valve. If no, you may need a new ignition control module OR some component in the safety string is open (spill switch, flame-rollout switch, flue damper........).
If you are not familiar with the components, get a professional in there.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
THIS!If you are not familiar with the components, get a professional in there.
@happysenior , where are you located?Baltimore, MD, USA
Consulting1 -
Do you have gas to the unit? Simple question but that is the best place to start. When you say you have power 24 volts of 120 volts. That valve is a 24 volt valve by the way.
- 128 Chimneys & Flues
