Honeywell L408J1009 Vaporstat POP sound
bklynick
Member Posts: 23
I just installed a Honeywell L408J1009 Vaporstat (purchased March 2019) to replace my original PA404A that wouldn't do better lower than 1.5-2.5psi.
It's been running the past few days as expected - not going over 1psi (12oz main, 8oz diff), but there is a "POP" sound at the start and end of the cycle and the gauge (0-5psi) pointer jumps. The normal microswitch click can be heard as well.
According to this thread, it may indicate a problem with the control:
https://forum.heatinghelp.com/discussion/164305/honeywell-l408j-1009-vaporstat-failures
But after reading through, I'm not sure if it's a symptom of a pending failure or if I should disregard if it's still functioning as configured.
Any advice would be appreciated as I hope I still may have time for a warranty replacement.
Thanks!
Thanks!
Mine started doing this, I think it inverted and damaged to disc when boiler when t under vacuum. It won’t operate correctly now. Kept popping when I took it off and tested it with a manometer and little hand pump bulb. It’s a expensive paperweight. It’s over a year old so not sure what I can do with it.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
