clouds exiting corroded pipe
subaru400
Member Posts: 33
I have a 1-pipe system that works great in all aspects, except that it has developed a somewhat significant leak under my crawl space, as a pipe has corroded through. I found this after I started up to test for the upcoming season, and figured I had a leak, since it was feeding back in way too much water. I cannot afford the fix right now, and was wondering if I can wrap it somehow this season and plan to get the repair next year. Is there a way to wrap it, and if so, what do I use? Don't really want to warp the floor above... thank you
They make pipe repair clamps, you need to know what size the pipe is, and understand that it is a temporary repair.0
They are called saddle clamps. Be sure to order/buy one that has a rubber seat rated for steam.0
Thanks folks - very much appreciated, and I'm glad I have a possible option until next year. I think I may have found something that will work locally thanks to your info and proper terminology.0
Before you get overly enamored with the repair clamp idea, note what @BobC said above. The way to fix this for any appreciable amount of time is to replace the pipe.subaru400 said:Thanks folks - very much appreciated, and I'm glad I have a possible option until next year. I think I may have found something that will work locally thanks to your info and proper terminology.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
Thank you; I'm actually scheduled to have it repaired next Friday.JohnNY said:
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 393 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
