Will making holes in a wall help spread the heated air from the kitchen to the bedroom?
agora
agora Member Posts: 2
Hi guys,
We would like to prepare ourselves better for the winter months.
In the kitchen, there is a big old wood stove we use for cooking and heating (it cannot heat the whole house but it drastically helps :smile: ) . Unfortunately, the kitchen is narrow and long and the stove is located far away from the door.
Our kitchen and our bedroom share a wall. I was thinking of letting some of this warm air (and it is VERY warm, much warmer than the other stove in the living room makes) in our bedroom by making a few openings in the wall.
Is it a good idea?
(I know that it won't be ideal with kitchen smells and noise - I'm an early riser and like to get a head start with cooking, oups :blush: )
How big should these holes be and where should I put them?
The stove is about: 1,4m/55 inches tall, 0.87m / 33 inches inches long and 0.69m/ 27 inches wide.
Thank you in advance for your advice!
  • Zman
    Zman Member Posts: 7,611
    To effectively do this, I would recommend cutting in a supply and return register and using a duct fan to move the air. You would need to approximate the heat loss of the bedroom to figure out the required flow rates.
    Albert Einstein
    Jamie Hall Member Posts: 26,913
    As @Zman says, just cutting holes won't help much. However, if you cut one opening near the top of the wall -- where the warm air collects -- and put registers and a fan in it (there are any number of good sources for duct fans) and then provide another opening -- bigger -- with registers at least for looks -- near the bottom of the wall, you could get very good results.
  • agora
    Thank you so much!!!
    If I manage to do this, I'll post a photo here :smile:
