Monoflo loop
bradcobill
bradcobill Member Posts: 6
Hello,
As part of a remodel, owner wants to add in a toe kick heater on to what is already a 3/4 monoflo loop. Can I tee in a monoflo off of the existing monoflo?
  • Ironman
    Ironman Member Posts: 7,871
    Sure, just keep the run as short as possible. You may need two monoflo Tees if it gets too long.
    Bob Boan
  • Eric_32
    Eric_32 Member Posts: 267
    You want to add a new mono flow tee on the "main line" or cut it in on the branch of an existing mono flow tee?
  • bradcobill
    There is already a 3/4 monoflo loop off off mains in basement. I want to cut in a 1/2 monoflo loop off of that 3/4 loop to pick up a new toe kick
    HVACNUT Member Posts: 7,237
    No. The 1/2" must be it's own branch circuit.
