Monoflo loop
bradcobill
Member Posts: 6
Hello,
As part of a remodel, owner wants to add in a toe kick heater on to what is already a 3/4 monoflo loop. Can I tee in a monoflo off of the existing monoflo?
Sure, just keep the run as short as possible. You may need two monoflo Tees if it gets too long.Bob Boan
You want to add a new mono flow tee on the "main line" or cut it in on the branch of an existing mono flow tee?
There is already a 3/4 monoflo loop off off mains in basement. I want to cut in a 1/2 monoflo loop off of that 3/4 loop to pick up a new toe kick0
No. The 1/2" must be it's own branch circuit.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
