Fin Tube Baseboard in kick Space of Kitchen banquette Seating
ced48
ced48 Member Posts: 469
Would installing some fin tube radiation in a recessed space in the seating of a banquette effect performance by much? I am talking about a space just tall and wide enough for the baseboard to fit into.
  • Ironman
    Ironman Member Posts: 7,939
    Yes, it will greatly reduce its output.
    Bob Boan
    hot_rod Member Posts: 28,024
    air movement across the element is what is needed cool air in the bottom, warm air out the top
  • ced48
    The reason I ask is that I have to replace 17' of fin tube and I only have 4' of wall space left. Everyone seems to be down on kick space units, and the mixing of panel radiators, and so forth. The system is a very small, split loop, and I know I have to be careful not to mess up the balance of the 2 loops. Any ideas would help.
  • Solid_Fuel_Man
    Why not a panel radiator?
  • STEVEusaPA
    Why can’t the space for the fin tube be a little deeper and taller for better convection?
    Either way you may have some toasty ankles.
    —side note—
    I saw at Penn Station in Philly they have an opening in the bottom of the benches, and fin tube in the bottom back of the bench, and a grill at the top back of the bench (and 30-40ft ceilings). They seem to work despite being fully plugged with trash/debris.
    Here’s a pic (I forgot to delete) from overhead (looking down the top/back of bench). I could take a better pic when I take the train to Wetstock.
    I only took the pics to email them telling them they could probably easily save 20% on their heating costs if they would clean them out. They never got back to me (or cleaned them).
  • ced48
    Yes, I was thinking of leaving some space over the baseboard for the hot air to escape, maybe the openings would be tapered up to nothing. I am only using 120 degree water, so no over heating of the ankle issues. A little concerned about heels kicking them.
    I am concerned about the pressure drop with 1/2" feeds on panel units, and how it could upset the balance of the two loops.
  • Ironman
    At 120* SWT, you'll only get 1/4 of the rated output. That's assuming the BBs are completely free to breath in their enclosures.
    Chocking the air flow is gonna make it substantially less than that.
    I wouldn't recommend what you're proposing.
    Bob Boan
  • Ironman
    Is the piping a series loop, direct return or monoflo?
    Bob Boan
  • ced48
    edited August 2019
    Standard Slant Fin 30 will get me 210 btu's per foot, Smith's He2, close to 290. I need the equivalent of 17 feet of Slant Fin 30 at these rates. I will only have 4 feet of outside wall left, after installing the new dining area.
    Yes, it is a split, series loop, direct return. Water exits boiler in 1" main, splits into 2, 3/4" lines, feeds the base board on each side, one after the other, each side returns to a common 1" line, back to the boiler.
    Cabinet heaters work basically as you describe, a large metal cabinet with fin tube assemble, much larger than fin tube enclosure.
    SlantFin does have high output fin, that looks to outperform the HE?
  • ced48
    Bob, What would you do in this case?
  • Ironman
    Without actually seeing what you're dealing with, it's hard to say. You mentioned panel rad's in another post?
    Bob Boan
