electric tankless water heater
franklinsfarms
Member Posts: 2
about to make decisions on which water heater to buy, wanted a Takagi but they only do gas heaters.
Hoping to eventually run the system on solar (or at least partially) which is why electric.
Existing wooden floor on top of which I will run pet hose and then a new subfloor and a finish floor.
2000 sq. ft. divided into 4 or 5 zones, plus one zone for a small bathroom downstairs from this with pet embedded into concrete.
Anyone have a good suggestion for a heater?
What you want is an electric boiler, not a water heater. There are quite a few on the market. Ideally you would use one with outdoor reset capabilities."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Figure your heating load before you buy anything...
As @Zman says, there are quite a few electric boilers on the market. Be sure that your electrical service can handle the load, however. As a WAG ballpark, you're likely to need at least 40 KW, which is over 150 amps on the normal residential 240 volt supply.
If you are planning to eventually go to solar photovoltaic, also keep in mind that in full sun, you will need a minimum (with current technology) of 200 square meters of solar panel to supply that load -- but that the sun doesn't always shine, so you'll need more (a typical WAG is 8 times the area) or 1600 square meters of panel (about a third of an acre), plus storage batteries (that's variable with where you live, of course).Br. Jamie, osb
May be worth looking into air to water heat pumps. Heat, cool and provide DHW at a much better efficiency, when compared to electric resistance boilers.Bob "hot rod" Rohr
Living the hydronic dream0 -
Thank you all, lots to look into.
I did think of augmenting the solar part with wind technology.
- 120 Geothermal
- 169 Indoor-Air Quality
