Bathroom Baseboard.
Aluminum or plastic covers. Try the Slant Fin website0
I replaced the baseboard covers in my bathroom with these plastic covers with good results.
https://getneatheat.com/1 -
For what it's worth I have a cast iron radiatior in my bathroom that's been there since the fifties without a speck of rust. Paint works wonders. With cast iron I think the humidity from the average shower or bath is of no concern. Keep the boiler free of air and your aim at the bowl halfway decent and a radiator will last forever and withstand much worse abuse than any fin tube.0
Thanks for the replies. I've seen the covers,i just don't like cover-ups,because the rust is still there underneath. It's my own house and since I'm in the trade,I have no problem removing what's there and replacing. But who knows,I might end up with the simple covers. My late spring/summer project. And since I need a new tankless coil, I'll be replacing the airscoop with a spirovent at the same time. And no room for an indirect,so it's a tankless I must go.0
I would move it to another part of the bathroom. I can't stand any kind of heating element next to the toilet. LolHomeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci0 -
Every foot of baseboard Slant/Fin now manufactures is galvanized under the paint. Residential baseboard is manufactured using pre-painted steel, so when the panels are formed the paint gets tiny cracks, and the rust generally started on these bends. when I first started working at Slant/Fin (25 years ago) we had an old engineer who used to recommend putting a good auto paste wax on baseboard going into bathrooms...he claimed that prevents rust.
We do have the Revital/Line extruded aluminum cover where the old front cover and damper are removed before the Revital/Line is installed. If you are concerned about keeping the old rusty rear panel, I recommend just using a rust protection paint on that and then cover it with a Revital/Line product. You will not see the rusty metal that was painted.
Personally, I would not worry about covering the rusty metal without painting it first. Just clean it if it is dirty to prevent smell when it heats up.
Keith Muhlmeister
Slant/Fin Corporation0 -
Panel radiator
- 125 Chimneys & Flues
