Replacing a rusted leaking 2 inch return pipe on an old peerless steam boiler circa 1983
Thomb
Thomb Member Posts: 15
Hi I have an old peerless steam boiler from 1983 with a rusted leaking 2" return pipe. I am worried about damaging the cast iron end section where the 2" return pipe threads into the boiler I patched the leak for now. I am waiting for the end of the heating season. A plumber told me he would use a pipe snapper to crush the pipe any suggestions or should I try to break it loose with a pipe wrench and some leverage ?
    EBEBRATT-Ed Member Posts: 20,387
    Very unlikely that the boiler will be damaged but I would not use a snapper. Cut the pipe off and wrench it out. 2' wrench with a cheater pipe.
    If it breaks off inside the boiler (could happen) cut a few slots inside the pipe with a sawzall or hacksaw blade go as deep as possible without cutting the threads. Cut the two slots 1/2" apart. Position the slots where you can get at the pipe with a hammer and chisel. Use a hammer and a cape chisel to pick the piece out. The rest of the pipe will collapse and come out. Not that difficult done all the time A small regular cold chisel will work
    ethicalpaulSuperTechSTEAM DOCTOR
    HVACNUT Member Posts: 7,507
    Is the Peerless a JOT?
    Sometimes heating the joint helps. A 4 ft wrench couldn't hurt either.
  • Ironman
    Ironman Member Posts: 7,918
    Not sure what the plumber meant by a "snapper"? Does he mean a soil pipe cutter? If so, that will be of no value on black iron pipe; it's made to cut cast iron pipe.
    Follow the advice above and you should be okay.
    35+ years is running on borrowed time for that boiler. You might wanna consider replacement and fix the return then.
    Bob Boan
    ethicalpaul Member Posts: 8,922
    Just as described above. Here's my adventure in this from earlier this winter. I cut it off, leaving a few inches in there, then put a 24" wrench on it (perhaps with helper pipe, can't recall).
    Photos are from this thread: https://forum.heatinghelp.com/discussion/168172/diy-false-main-repipe-diary#latest
    StuckWithSteam
    Good job @ethicalpaul
    Guess it really did need replacing
  • HydroNiCK
    HydroNiCK Member Posts: 186
    If you dont have a 3-4ft wrench and or its starting to rip the nipple...and you have access to a welder.....cut the pipe to about the same length as Paul did.
    Tack a hex bushing onto it. Use a impact wrench to unscrew it. You can heat it with a torch first using whatever removal method you want to try.. just be careful about burning insulation.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,617
    All good ideas. Personally, I would saw off,leaving some pipe sticking out and cut and chisel. Shouldn't take more than a few minutes.
