Friend’s steam system
Member Posts: 5,704
When you find out your friend has a 19th century two-family home with steam, you make him show it to you, am I right?
- Pressuretroll cut-in set above 8
- 4 mains, 3 with Gorton 1’s, one no vent at all, just a plug. One of the Gortons apparently failed closed due to cold main pipe at the vent.
He started to think I was magic when I told him he must have some cold radiators.
- and then, the steam supply pipe is like 1-1/2” copper 😭 but it goes to a nice big 3-1/2 or 4” iron header and the water level was steady and I heard no surging so he’s lucky there but I told him a good steam guy could fix it easy if it started to give him problems or leak.
NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el
The boiler piping : https://youtu.be/ca9GuwuOVZcSingle pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment4
That installer didn’t earn their money, they stole it from the homeowner. Truly sad.4
@ethicalpaul if and when your friend needs help with his system? I hope that he will follow your well educated advice.1
This. That Weil-McLain boiler has a 3-inch tapping but the guy was lazy and bushed it down to 2-inch. Fortunately replacing that copper with 3-inch black steel shouldn't be that hard.KC_Jones said:That installer didn’t earn their money, they stole it from the homeowner. Truly sad.
Consulting1 -
> @IamNotLost said:
> As I/We ponder after all you have learned , accomplished and excelled . . your restraint.... Humility ? Economics ? it's complicated ? .... and how you're planning to subtlety share with your friend some information , perhaps a book from the Store..
Oh I wasn’t stingy with my opinions! We turned down his p-troll and I advised him what main vents to install/have installed, and I told him about this place and that his installer and service tech are dangerousNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el6
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
