Golf balls
DZoro
DZoro Member Posts: 1,048
So todays job was removal of a old lowboy furnace. I free up the ductwork, kick out the 4 bricks, and furnace doesn't fall to the ground. Check ductwork, all free, hmm didn't check under the furnace..... Put my left hand on the furnace to see what's under it, and the furnace moves. It moves very, very well, it turns easily. I found 6 golf balls under the furnace keeping it from falling to the ground.
I have never thought about using golf balls, habit for many, many years was black pipe. Hmm not anymore, I'm going to be keeping golf balls in my truck from now on :). I couldn't believe how easily it rolls you can spin it, turn it, push it, so easily it was actually fun :p
The home owner threw the golf balls in my bag, says looks like you will need them before me>>
Thought I'd share a tip to those who may or may not have tried it before.
FORE!
D
Paul PolletskcoppSolid_Fuel_ManratioSTEVEusaPACanuckerAlan (California Radiant) ForbesGroundUpmattmia2EdTheHeaterManMikeAmannSuperTechttekushan_3JOutterbridgeGrallertPeteAgassymanMad Dog_2
    Great tip! I'll have to go get some golf balls!
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 20,485
    What's the old saying? "Nothing rolls like a ball"
    Mad Dog_2
  • CLamb
    CLamb Member Posts: 348
    Will they hold up a boiler as well?
    Mad Dog_2
  • DZoro
    @CLamb I don't see why not. They are quite robust, worth a try. The more you put under the more weight they can handle. What I was impressed with compared to pipes, you could spin and turn so easily. With pipes you can only go the direction they are facing.
    D
    hot1JOutterbridge
  • Gordy
    Gordy Member Posts: 9,546
    Thats a good apprentice trip to the truck. Go get the golf balls out of my truck............
    It was probably one of those moments when the only resource they had was golf balls, and it worked out well.
    JOutterbridge
  • SeanBeans
    SeanBeans Member Posts: 525
    I used a couple of 410a cans to get a magic pack out of a tight room a few weeks ago xP
    mattmia2 Member Posts: 17,478
    I'm sure some kids shoved them under there in one manner or another.
    Golf balls will work if the floor is level
    EdTheHeaterMan Member Posts: 12,508
    Bowling balls will work if the floor has some rough spots.
    mattmia2MikeAmannttekushan_3mvickers
    This will work on all other terrane
    JOutterbridge
  • UPdrafter
    UPdrafter Member Posts: 1
    Great suggestion!
  • mvickers
    mvickers Member Posts: 30
    This guy's got a few secrets for moving HUGE, 1ton slabs
  • CLamb
    So perhaps the game of golf was just a byproduct of moving blocks? Considering the game that makes a lot of sense to me.
    This reminds me of something though. Moving something heavy on anything that rolls can be a problem unless you use pipe rollers things can literally go sideways.
    A guy that I worked with told me about "soapers".
    A piece of plywood or wood on the floor, a piece of wood attached to the thing your moving and Ivory soap between the two pieces of wood. He said it would allow the load to be moved but provided enough friction so it would not take off on you.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,681
    Make sure they are Titilist...Mad Dog 🐕
    hot_rod Member Posts: 27,856
    edited March 2024
    We use soap out here :)
    Hopefully it washer out before I drive over it.
    The on and off ramps are built with foam blocks.
