Moving My 30 psi Guage
dlipter
dlipter Member Posts: 61
I want to remove my 30 psi guage install a nipple, elbo and riser to elevate it so I can raise the Taco box so I can swing open the Boiler door.
Any reaason why I couldn't or shouldn't do this?
Why does the gauge say "Internal Syphon"?
    Jamie Hall Member Posts: 27,751
    No problem. Move it as you like, just keep it. While you're at it, why not mount a 0 to 3 psi gauge on the same pigtail -- a T and a few more elbows and nipples.
    Internal siphon simply means the inside the gauge there is, supposedly, a tubing configuration which is intended to protect it from evil stuff outside. Don't count on it.
  • dlipter
    Did the 0-3 psi already plus skim port!
    There you go. Short memory...
  • dlipter
    New placement, I used 45 deg elbows for easier guage reading.
    EBEBRATT-Ed Member Posts: 20,957
    You could plug or ap the gage opening and put both gages on the pressure control pipe which would give you more room
  • Fred
    Fred Member Posts: 8,542
    Just put a cross fitting on the pigtail instead of the Tee that the 0-3 PSI gauge is mounted on and have that gauge on one side of the Pressuretrol and the 0-30 gauge on the other side. That gives you plenty of room for your taco box.
  • dlipter
    Great idea for the plug and cross fitting! I'll keep that in mind.
