Triangle Tube Not Working
hi my name is Ed I work in the Triangle Tube tech support dept.
it sounds as if the issue may be in the thermostat or thermostat wire something loose and not making a proper connection
if you need further assistance feel free to call me 856 228 8881 ext 155 we are here Mon through Thurs 8 to 5 and Fri 8 to 4:30 eastern time
thank you
Ed4 -
Thanks Ed. This morning for the first time the boiler gave an "E 122" message. First time that has happened as usual message is an "A" when it stalls. I have both wired and wireless thermostats and neither are able to get the boiler working.
thanks,0 -
You best move would be to take Ed up on his offer.
If you want more help here, you will need to provide more info. There are dozens of ways to wire one of these. Some pictures and/or sketch of the controls would be needed.
It sounds like Ed thinks you are getting a flaky "close" from something on the t-stat/heat call side of things. He is probably correct. They have a lot of experience with issues like this."If you can't explain it simply, you don't understand it well enough"
Albert Einstein4 -
I think the "A" showes up when the boiler is powered up and is not and error code per say. The "E" 122 is and the book says it is a temp. sensor drift. Have you added any zones or shut off any valves?0
Having just commissioned a Triangle Tube CC50s in my workshop, I am impressed that a company tech is following this forum. The OP would be insane to not jump on the offer of a phone call with a factory rep. He should run, not walk, to the telephone.Zman said:You best move would be to take Ed up on his offer.
I sounds like Ed thinks you are getting a flaky "close" from something on the t-stat/heat call side of things. He is probably correct. They have a lot of experience with issues like this.-1 -
sorry I haven't been on in a few days to see your follow up post the E122 is a sensor drift which normally means not enough water is moving through the heat exchanger
I would be happy to go through the ohm readings on the sensors with you or I can email you a resistance chart my
my number here is 856 228 8881 x 155
email is ed.nelson@acv.com0 -
Hi Ed,ednelson said:sorry I haven't been on in a few days to see your follow up post the E122 is a sensor drift which normally means not enough water is moving through the heat exchanger
I don’t want to hijack this thread, but if you have a minute, please take a look at a question I will pose in a new thread with “CC50s” in the title.1 -
Hi Ed,
Thanks for the offer and I will call you. I have had the service guy out several times and he has been on the phone with the Triangle rep and they have tried everything. It works fine for 24 hours and then locks up with an "A" and will not respond to a call for heat. My zone valves are respond to the thermostats but the boiler does not. If I hit the reset button, it cycles through and provides heat for about 24 hours and then stops. I will call you.
Thanks0 -
- 119 Geothermal
- 394 Solar
