Water empty system.
CJL
CJL Member Posts: 7
I have a one pipe steam system, and recently my system will not stop emptying itself of water through the over flow line underneath the back flow preventer. Once I manually refill the tank with water it will start to empty all the water out. any suggestions as to why?
  • ratio
    ratio Member Posts: 4,264
    Post a few pics, standing far enough back to see more than just a little bit of pipe.
    Jamie Hall Member Posts: 27,580
    Most likely the backflow preventer is shot -- but I'd have to see pictures of the install to say for sure.
  • Intplm.
    Intplm. Member Posts: 3,081
    How did you make out with your BFP feeding your boiler? Let me know what type of BFP it is and I can probably help.
