Replacement burner tubes for old hot water furnace
I have a small apartment building with 2 hot water natural gas furnaces. Gaz industries GS 400 400K input 320K output
. They work well enough but the burner tubes have seen better days and the flame isn't as blue as it used to be. I would like to know where I could get replacement burner tubes. I know the furnaces are old and inefficient but they are very reliable and keep the 24 apartments toasty.
Thanks for any help.
John
    EBEBRATT-Ed Member Posts: 20,995
    Usually nothing much goes wrong with the tubes unless they are warped or damaged. Are they cast iron, aluminum or steel? I would suggest checking with the manufacturer if they are still in business. Looks like a Canadian product. Just working around the burners will stir up dust and change the flame color. I would check the boilers with a combustion analyzer. That will tell you what is going on. The burners may need just a good cleaning
    If they are not still around you may be out of luck. Possibly you could get enough good burner tubes to keep 1 running and replace 1 boiler at a time
    1-877-929-1214 telephone
    They are still in business and making the same type of boilers
