If you've found help here, check back in to let us know how everything worked out.
It's a great way to thank those who helped you.
Today I went up to my unfinished attic, which is totally sealed off from my home (and freezing!), and noticed that the valve must be open and because the vent is spitting/leaking it's hot. This will be an issue once we have some ice (melting the roof, etc) I assume, not to mention I don't want to be heating the attic!
I can replace the vent but curious if it's okay to just shut it on at the main valve. I have another radiator I've shut off at the valve, due to it being a kid playroom.
If I do shut it off, is there a good or bad time to do that? If I shut it off while the system is on, water will be stuck in the radiator after it condensates - is that a problem? If I shut the system off to shut it off, how long do I need to wait for it to cool. Same question goes for replacing the vent.
0 ·
But that doesn’t matter much because then I’d disassemble the pipe and cap it!!
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
Hoffman Equipped System (all original except boiler), Weil-Mclain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
I would remove the steam line valve and cap it, as ethicalpaul suggests.
