New York (YONKERS) Steam plumber recommendation?
grye
Member Posts: 90
Hi all.
After a lot of threads and PMs I have identified the most probably cause for my imbalanced system issue. I need to either drill and tap an angled main vent into a vertical return, or pipe in a sideways T for a straight vent. I know neither are ideal (not far enough back from return, water hammer potential etc), just the way my system is and what needs to happen.
I've had several plumbers come, but none of them really knew steam systems. On one hand I could tell them exactly what I want done, but i'd rather somebody that knew why I wanted it done and maybe consider other factors that i'm not.
Any reputable steam plumbers in/around Yonkers or the Bronx?
Good heavens yes. Try the "Find a Contractor" tab on the main page of this site, clicking on New York State (don't use the zip code feature). All the folks there are good.Br. Jamie, osb
Thanks Jamie. I tried that by zip, and only one came up. Last time I needed something I called and they didn’t service my area. @Jamie Hall0
I Service Yonkers area @grye send me a private message and maybe we can set something up.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
