Wi-fi thermostat on a gas-fired boiler w/baseboard heating
Scappy
Member Posts: 1
Hi all, I think I have a simple question. Will a wi-fi enabled thermostat work on a gas-fired, hot water boiler with baseboard heating? The reason I ask is because all the literature I read makes reference to furnace rather than boiler. Thanks for any input.
It will work. Whether you want to use features such as deep non-occupied setbacks and so on is another question, since they will cost you fuel.
If you do put one in, be sure -- be absolutely sure -- that your wi-fi router is protected by a secure, unique network name andpassword and that the thermostat also is protected by a secure, unique password.Br. Jamie, osb
Inexplicably, over 85% of the USA heats their home with a forced-air furnace. That's why a great deal of literature on things like this seem to speak to that market. It will work fine on your equipment.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
It would need a common wire so may not be a DIY job.0
- 120 Geothermal
- 394 Solar
