Radiator to fit 17-inch wall width
I am redecorating my kitchen and looking to find a radiator that will fit a 17.5 inch wall including valves. We need around 4000 BTUs for a hydronic system. Is there such a radiator that will fit in this mall in opening?
Is there such a thing as a silent under cabinet radiator? I hate blower noise in the am.
Thanks,
Steve
Steve from Denver, CO
    hot_rod Member Posts: 26,588
    Runtal has a wide selection of verticals. I've seen some with hooks to hang jackets and hats on.
    You can also custom build a radiant wall, should be able to get 25- 30 but per square foot from a radiant wall. Just use some ThermoFin and sheetrock or wood over them.
    https://www.dropbox.com/s/idb7te766wzm5s2/Screenshot 2018-10-10 17.45.14.png?dl=0
  • delta T
    delta T Member Posts: 884
    edited October 2018
    I second Runtal:
    https://runtalnorthamerica.com/residential_radiators/vertical-hx-radiators.html
    5 tube 14.3" width you will need about a 6' height assuming 180 degree average temperature. Depends on the operating temp of your system to size properly.
    Alan (California Radiant) Forbes Member Posts: 4,643
    edited October 2018
    I like Runtal as well and I especially like their towel warmers in kitchens and bathrooms.
    They have a TW21, 61" high x 16" wide that has an output of 3520 BTU's at 180°F water temperature.
    https://runtalnorthamerica.com/towel_radiators/omnipanel.html
    With all the appliances in the kitchen generating heat, I don't think you would miss the 500 BTU shortfall.
    delta T
  • kcopp
    kcopp Member Posts: 4,630
    Biasi/ Purmo makes a 16 wide x 36 high panel radiator.
    4240 btu.
    A lot less $$$ than Runtal
  • Zman
    Zman Member Posts: 7,611
    4240 btu.
    True, They stick out quite a ways though.
    Embrace your inner artist and build one like @Hotrod using copper tubing and cool metal artifacts :D
    Albert Einstein
    delta TKLaughkcoppCanucker
