Radiator to fit 17-inch wall width
Steve Garson_2
Member Posts: 712
I am redecorating my kitchen and looking to find a radiator that will fit a 17.5 inch wall including valves. We need around 4000 BTUs for a hydronic system. Is there such a radiator that will fit in this mall in opening?
Is there such a thing as a silent under cabinet radiator? I hate blower noise in the am.
Thanks,
Steve
Thanks,
Steve
Steve from Denver, CO
Runtal has a wide selection of verticals. I've seen some with hooks to hang jackets and hats on.
You can also custom build a radiant wall, should be able to get 25- 30 but per square foot from a radiant wall. Just use some ThermoFin and sheetrock or wood over them.
https://www.dropbox.com/s/idb7te766wzm5s2/Screenshot 2018-10-10 17.45.14.png?dl=0Bob "hot rod" Rohr
I second Runtal:
https://runtalnorthamerica.com/residential_radiators/vertical-hx-radiators.html
5 tube 14.3" width you will need about a 6' height assuming 180 degree average temperature. Depends on the operating temp of your system to size properly.0 -
I like Runtal as well and I especially like their towel warmers in kitchens and bathrooms.
They have a TW21, 61" high x 16" wide that has an output of 3520 BTU's at 180°F water temperature.
https://runtalnorthamerica.com/towel_radiators/omnipanel.html
With all the appliances in the kitchen generating heat, I don't think you would miss the 500 BTU shortfall.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
Biasi/ Purmo makes a 16 wide x 36 high panel radiator.
4240 btu.
A lot less $$$ than Runtal0 -
True, They stick out quite a ways though.kcopp said:Biasi/ Purmo makes a 16 wide x 36 high panel radiator.
4240 btu.
Embrace your inner artist and build one like @Hotrod using copper tubing and cool metal artifacts"If you can't explain it simply, you don't understand it well enough"
Albert Einstein4
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
