Radiant Pump Issues
Brl1977
Member Posts: 6
Hey Guys, I've got a big problem. No matter what I do I can't get any flow to my radiant loops. At first I thought the pump was junk but I fear it's way more then that. There is a Taco I-Series 3-way to the left of the pump. Boiler has internal system pump. Air Sep loop has hoy water but that is it. Any help would be awesome. Thanks, Brian
one if the ball valves on the manifold is closed. The blue caps need to be open alsoBob "hot rod" Rohr
Living the hydronic dream0 -
I see no way to get flow through the main loop with the air separator in it. The boiler circ will just short cycle back to the boiler and the load circ same thing, since they are both hydraulically separated from the main loop. Piping looks seasoned though, this must have worked at some point?0
Thanks Zman! I'll get on it this week/weekend.0
So got it repiped! Filled and got the air out. Turned a loop on, pump came in and nothing again. Pulled the motor out of the housing and pumped it and find out it’s running in reverse? Anyone seen this? Is there a fix?0
That's great. 120 is probably about right on your design day. I would recommend setting up outdoor reset and seeing how low you can go. I bet the typical heating day only needs to be about 100."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
