L. P. Gas piping sizing
bean
Member Posts: 34
Can anyone offer some assistance on helping me size L.P. gas line for higher pressure systems? (10 -90 psi) Also on lower pressure systems (11 " W.C.) Thanks for the help!!
90 psi? Is this a commercial system and if so are you planning vaporizers? and yes..either message me or post it here we can work out the line sizing easy enough..0
For normal piping setups you can just use the chart in the fuel code. https://codes.iccsafe.org/public/document/IFGC2018/chapter-4-gas-piping-installations
If you want to figure out odd ones, try using the enginnering tool box for natural gas and change the specific gravity to 1.5 for propane.
https://www.engineeringtoolbox.com/natural-gas-pipe-calculator-d_1042.html"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
need btu loads and length of pipe, ie a diagram of what you are doing"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.8K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 773 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
- 19 Recall Announcements
