Trying to find a strange fitting
Anvil still offers them, found some on ebay and at Graingers, get your wallet outBob "hot rod" Rohr
Living the hydronic dream0 -
in stock, 1 day shipping. not sure about Canadian shipping?Bob "hot rod" Rohr
They call it MickeyMouse to use hose & clamp,but....0
Those are 300# fittings. That's why they're expensive, but they'll work just fine.Bob Boan
> That says temp range from -20 to 150 degrees. That would work on a condensate return but may not on a steam supply?
Er Fred, you feeling ok?
It's a cast iron fitting. Its probably safe to say those temperature specs are a mistake.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Er @ChrisJ , not all cast iron is created equal. I've seen cast iron waste pipe crack from excessive heat. It is always better to ask the question first, then do the work than to do the work, then say Wow, why'd that happen?ChrisJ said:> @Fred said:
It's a cast iron fitting. Its probably safe to say those temperature specs are a mistake.0 -
It's not a cast iron poop pipe.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The spec is not a mistake. All of the Zoro cast iron fittings say -20 to 150 degrees. I will accept @Ironman 's knowledge/experience, you, not so muchChrisJ said:> @Fred said:
It's not a cast iron poop pipe.0 -
All cast iron fittings on Zoro have the same spec, and yet you feel it's not a mistake.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Ironman said:
Uh, actually, 300# fittings are malleable iron; 150# are cast. You can break a cast fitting with two hammers; a malleable fitting, you'll be beating for a long time.
I'm not sure what the difference is but they claim this is 125 not 150.
It's rated up to 150F @ 175 PSI.
That's where that spec comes from.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I think it's a temperature/ pressure relationship. Check with the manufacturer for clarification.Bob "hot rod" Rohr
What I'm seeing here is a contradiction.
The temperature of steam at the spec of 125 PSIG is just over 352° F.
Yet the Temp. Range spec shows a maximum of 150° F.
I think someone typed something in wrong. Check with the manufacturer.All Steamed Up, Inc.
Consulting1 -
Zoro is not the manufacturer, Anvil is.
I think that explains some of the confusion. Also, the pic is showing what appears to be a 300# malleable Ell while the description says it's cast.
Check with the manufacture, but it will work fine with steam. I've yet to see an iron fitting that couldn't take 215* steam.
I also think hot rod's explanation makes the most sense. We're living in a day when everything has to be rated 9 ways from Sunday. This is what lawyers and politicians have created.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Thank you for the information it is greatly appreciated. I owe one and all an apology the book I was looking at when I wanted to see if the deadmen had these fittings was. The Crane Cataloque circa 1924. This book is one of my favourite books to go to ,when I see something weird and wonderful ,and I do not have a clue what it is. I have to say in the days of the deadmen ,they did things in an elegant way. The book is over three hundred pages ,high quality glossey paper, and bound like an expensive novel. In my own defense .I said it was Hoffman and I cannot tell you why. I would suppose it has something to with bring an old phart. All the best Jack Canada0
Did you find one? I order them from Ferguson Enterprises once in awhile; they have MI, CI, and forged. Forged is cheaper than CI for some reason.... MI and CI are both Anvil, but I don't recall the forged MFG0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
