Steam Piping Tables
bean
You don't want the hydronic heating anyway -- the tables you need are in The Lost Art, and you should have a copy if you're playing with steam.Br. Jamie, osb
I am currently reading The Lost Art Revisited.Where would I find this chart?0
Several places, since the sizing depends on the type of steam piping involved (one pipe parallel, one pipe counterflow, two pipe feed, two pipe returns). You're in the right place, though! I'd give you page numbers, but they're different in revisited, and I don't have that (yet)Br. Jamie, osb
Do you think Dan H. would know?0
Probably. But there's nearly a dozen sizing tables in the single pipe chapter, and about the same in the two-pipe chapter, depending on which particular pipe you're sizing.
What, exactly, are you trying to do? Don't worry if you don't know the right names of things, just describe it and add pictures.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
