pigtail all wrong
aarondavid
Member Posts: 9
Hi new to the boards here. Recently ordered and have been reading Dans book about “ we got steam heat”. the few paragraphs on the orientation of the pigtail were enlightening. Mines is all wrong but doesn’t look like it can just be turned the right way because it’s connected to the sight glass. i’ve included some pics. how can this be corrected? it’s a penco boiler that was here when i purchased the house.
What were they thinking? As @Fred said, it'll work that way just fine -- since it is a microswitch type. I'd not fiddle with it.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1 -
The loop should be holding water, so it's at least functional, and the pressuretrol seems to be set as low as it can go, so you've got that in your favor as well!
That said, it does look like crap. To fix it, you'll need to remove the upper sight glass valve & either spin the tee around until the piggytail is level, or (what I'd suggest, if you do decide to fool with it) pull the tee off & start over with it.
-1 -
Could you please back up a few feet and take a picture of the rest of the boiler piping.0
aarondavid said:sure!!!!
Alan Welch said:Could you please back up a few feet and take a picture of the rest of the boiler piping.
In your other post you mentioned that you have severe water hammer, is that something new? I think the boiler piping may be a big part of your problem. Not familiar with that boiler, and can't tell from the pictures, but it looks like 2 supplies leave the rear of the boiler with the supply tee in between them. A definite piping no no.0
I am afraid you have some issues...New England SteamWorks
newenglandsteamworks.com0 -
It seems like this heating season it was the worst it’s ever been. This is the setup i’ve inherited. Would like to right the wrongs this summer. It’s warming up weather wise here in NJ now.0 -
You need a steam expert.
You could insulate all the pipes yourself, get the good stuff not that foam junk, all steam lines need to be insulated at least the supplies or you are turning to condensate before the radiators and that will cause all kinds of issues including hammer.
Check for any missing or broken pipe hangers and check pipe pitch, old homes settle and pipes don't.0 -
I would also suggest replacing that dry base junk boiler with something better like a Weil McLain, when you have the money, get one of the experts here in your area to do it and address any other piping issues at the same time.0
i agree
It will also be easier to check the slope of the pipes, and re-support if needed, without insulation on them.--NBC0
thanks so much0
the site glass looks like mud..be curious to see whats in the water....0
I agree on checking the slope of the pipes before insulating them. Much easier. On the other hand, to respond to @the_donut 's comment, insulating the pipes is something the homeowner can do (as is correcting the slope of any sagging pipes) , easily, in a weekend -- and always makes a positive difference. So why not go ahead an do it?Br. Jamie, osb
- 114 Geothermal
